Bready Battery Tray
hey guys, pretty new to this.
i recently purchased an 89 polo breadvan and i checked the battery tray and there is no noticable rotting but i can tell its been repaired before..yet my carpet is still getting wet. just wandering what the best ways to fix the battery tray are without welding.
Can any of you reccomend some good products?
Cheers,
Ryan
My fix is a pikey fix. Bit of 1mm aluminium bigger than the hole, then tiger seal.
It was fibre glassed before I did this.
Welding is winning though, I just don't want to pay someone for that just yet.
how sure are you that the leak is coming from the battery tray? it only takes a tiny pinhole to let enough water through so soak the footwell. I had a gt coupe a few years ago that had a rotted battery tray. A mate and I welded it back up (dash still in situ) but the car was still getting wet footwells. turned out the water was getting in through a rust scab, right on the corner of the windscreen seal. Upon removal of the scab, I noticed that the metal had rusted through, as I could see a small pinhole of light through it. As a test I covered the area with some putty and the wet footwell dried up. worth checking, that's all.
have the dash tray out and check its leaking there...rough it up with coarse sand paper until the rust has gone and apply a nice thick smear of fibre glass paste underneath
then clean up the top side and same again if needed , and paint or underseal
@Craig, thanks for your advice :) I've heard tiger seal is pretty good stuff.
@g40jon i removed the tray under the dash in the drivers footwell and poored water to find the leak, it is deffinatley from the battery tray but from above there is no noticable leak or rust, but just below it is realy rust, i cleaned it up with some coarse sandpaper and got all the flakey bits of rust off, and fibreglassed it pretty well. It stopped the water for about a week and then broke through it again. any chance the leak could be just under the drainage hole or is that a pipe? Thanks for the tip though :)
@Steveo yeah I've tried all that apart from the underseal, is that the best thing to go over the fibreglass for a job like this?
Thanks for your replys guys appreciate it :-)
personaly i prefer gloss paint as you can if any further probs appear ...underseal hides too much
Ah I see, will give it a go thanks mate
