self tinting
Hi,
Been looking around and the cheapest price i can find is £150 for tinting the back 3 windows, and seeing as I could use that on better mods such as new wheels would it be easier to just buy the tints and do it myself?
opinions? or advice?
  • Views 869
depends how nice you want it ...its very very hard to get it perfect with no bits under the film etc
if you will settle for some imperfections maybe have a go , the rear screen is hardest , have a look on google theres ways to shrink the film to fit to the curve
I found it easy on the sides but good luck on rear window maybe a spare pair of hands and a dryer for the rear just make sure you clean the windows a few times not as hard as you think I think it's over priced for tinting IMO
that's exactly why i don't want to pay the quoted price, however reading about it it does seem that the rear window is a pain so will get a spare pair of hands are the pre cut ones any good or should i stick to a solid role and trim myself?
I work I vinyl or tho not as much window tinting we do window frosting etc.
My advice:
Prep well. Clean the windows a good few times as smallest bits of dust will show through..
Spray bottle with water in and a drop or two of fairy liquid. This gives you a saving grace when fitting in the fact you can move and slide around while you are getting into a happy position. Also it can never be too wet as when applicated will just run out.
Old credit card will be needed to applicate. Would recommend to put a soft edge on there with some double sided tape so not to scratch the material when pressing.
Also an idea that may help a lot is to make a template of the window and pre cut to make trimming minimalistic. But try to leave a bit of overlap just I case it moves!
When applicating try to work in one motion. E.g left to right or up to down or vice versa but makes it easier to see where has been applicated.
If your feeling a bit unconfident with it.
Could do a join halfway down and have a 1/2mm overlap.
Any other questions feel free to ask. Worth looking at some YouTube videos to get an idea of people's styles in doing it and see what you think will suite you best.
Sweet, thank you very much!
Will spend a lot of time on youtube then!
Any other questions ill ask!
