Fit a Sub Wiring Kit to 2010 Polo
I am looking to fit a sub into my 2010 polo 6r, i have wired up a sub in my previous car 106, but as this is a newer car there is nowhere for the power cable to feed from engine bay to car ? could anyone help me with this or does someone live near by to help me do this i will pay £
  • Views 4.5k
i have fitted sub now got a line converter for sub to work with vw cdplayer.
In the passenger footwell, the left side kick panel comes off to reveal a grommet. The wire can be passed through the grommet, around and in behind the wheel guard (which you need to take off), and up through an existing hole at the top adjacent to battery.
Failing that you can drill you own hole somewhere or you can run the wire under the car and then up through the boot. Hope this helps.
Sorry to Hijack the Thread. But would this be the same on a 9N3 GTi???
