1.0L 6n convertion into 1.4 16v
was just wondering if it is a stright swap or do i need to cut anything for it to fit?
  • Replies 10
  • Views 891
can anyone help please?
Thanks in advance
Bumping your question after 1.5hrs is'nt going to do you any favours with the Mods!!
All your answers will be found in the FAQ's in the Engine section or try looking at a few build threads, that's what the "search" button is there for!!
I wasnt trying to, i just wanted an answer to my question, plus i've tryed looking and cant find anything can you help at all?
look harder! ha ;)
No cutting needed, will fit on the existing mounts as the engine is out of the same car lol.
Will need:
Engine + gearbox
Ecu + transponder and key
fuel pump
Engine loom
Brakes and hubs
driveshafts (possibly)
bigger radiator
and possibly selector.
might have missed some stuff there but think thats about it
Will need:
Engine + gearbox
fuel pump
Engine loom
Brakes and hubs
bigger radiator
According to vagcat the radiator and fuel pump are both the same parts and don't need to be changed.
As far as i can tell the drive shafts are the same as well.
I would replace the interior loom so you get central locking, electric windows, etc also while you are there you may as well fit abs.
my build is more a reshell than a conversion. :lol:
Will need:
Engine + gearbox
fuel pump
Engine loom
Brakes and hubs
bigger radiator
Nice one mate thanks
Will need:
Engine + gearbox
fuel pump
Engine loom
Brakes and hubs
bigger radiator
thanks for all your help i think i will be doing this convertion going to start a new thread in the build section
There are two fuel pumps listed.
One is a 1BAR fuel pump, the other is a 3BAR fuel pump. The engine codes that use the 3BAR are: "AEE, AFH, AHS, AER, AEX, AKV"
Part number: "1H0 919 651 P" . Think the 1.0L was AER? So should get away with it!
thanks
