knocking/rattle from boot area
Put some foam strips under parcel shelf, and foam is still intact to push down on it from above.
Spare wheel is secured. As are the tools.
It sounds like it could be boot lock, it's real loud over very rough roads, but the boot feels solid! No movement at all.
Anyone else experienced this and found a cure!? Killing me.
Edited by Matty_26
  • Views 2.1k
Bit of a stab in the dark but check your back seat belts or not knocking off the side of the car, also check your rear bump stocks and shockies - make sure it's snug in the rear turrets and not flapping around.
bonnets and boots have wind in rubber stops.. if its shutting fine the lock is in the right place, you just have to unwind the lil rubber blocks a turn or so. would feel it in the boot if ti was this.. could be exhaust catching heat shield, lots of cheap exhausts dont quite fit right and cause this.. could be any manner of things. if you cant find it just start taking things out one by one till the back of the car is empty. will soon figure what it is
Cheers guys!
Not seatbelts, put them in their holder, exhuast is new standard with new rubbers. Will check again. Sound like it's defo coming from inside boot area. When I see my parcel shelf jumping, I hear it. But I know it's not the shelf.
Yup, I'll have to start taking thingsout one by one I think!
Unwound the rubber stops a little!
And wrapped some tape around boot lock pin, as the original plastic around this had completely split in half!!
It's now silent!! :DDD
Edited by Matty_26
