Fibre Glass
I'm wanting to modify my door cards to removed the pocket recess (mk2). I've roughly filled the space with wood but the rough finish will show through the material I intend to cover them with. Therefore I was thinking a thin layer of fibre glass could be used to smooth things out. Feasible? I've never used fiberglass before and the majority of how tos I can find regard making a mould first to shape it, which is not what I'm looking to do. Although the finshe does not need to be glass smooth, would I need to skim the fibre glass with filler after or will the finish be smooth enough/be suitable to smooth?
Can anyone offer any advice?
Thanks in advance
  • Replies 17
  • Views 1.7k
wouldnt say it would be amazingly hard to get the finish you want. one of those box kits from halfords with the fibreglass sheet and resin should be ok as long as the wood covers the entire recess in the doorcard. doubt you'd need to skim with filler after as long as the surface the FG is covering is smooth to begin with.
Entire recess, how do you mean? Like no huge gaps?
What's the difference between mat and fleece? From what I understand the fleece goes on first and the mat is used to build it up?
id pad it out best you can with mdf then use the fibre glass paste to fill over the gaps ...will need sanding afterwards
Just the paste, no matting?
Found a few more how tos since posting this. Why do people bother making heavy MDF enclosures when fibreglass seems pretty easy. Does it tend to flex?
thin fibre glass isnt always suitable for a speaker enclosure , you idealy want dense material like mdf so its solid for the speaker to kick against
i would use this..or even cheap body filler if youve filled the worst with mdf
http://www.ebay.co.uk/itm/Glass-Fibre-Comp...=item43a7d34202
Well that's what I thought. So why are a lot of custom enclosures made of glass? Because you can have silly shapes?
well yeah ...easy to make fairly wild shapes , google where they make a speaker ring and stretch sweat shirt over it then resin it
swings n round abouts ...differant materials suit differant jobs
put some pics with what you are doing , if you wanted to go with mat n resin you can mock up the flat surface with parcel tape and fibre glass from behind , peel off the tape and its dead flat
Edited by steveo3002
I guess I could make a flat panel and cut it to size. I think I'm going to add a speaker ring though, so using fabric and matting is probably the best idea.
Cheers for the advice. I've just read a load more how tos and seen the t-shirt/fabric trick. Always wondered how they made those shapes. How do you mean 'mock up with parcel'? and how would it be fully flat? I'm assuming you mean parcel tape? Wouldn't the overlapping pieces of tape create a texture/pattern?
yeah sorry i meant parcel tape
for example....if you had a round hole in a door card , parcel tape over the front of the card to cover the hole , apply fibre glass of your choice to the rear side , then once its dry pull it all off and it will leave a pretty nice smooth surface vs one that needs lots of sanding
I get you, so the sticky size of the tape would be attached to the fibre glass until it's pulled off? An idea, will need to have a look to see what's what.
Edited by prankstar2003
yeah thats it..just peels off
Cool, I'll have a think about that.
What do you think of using FG for sub enclousures? I'm trying to keep weight down where possible so I'm considering a frame with cloth stretched over it. No flashy shapes really, just a simple box shape.
I've got the audioscape ones in my golfs where they fit around the rear arch, they're fibre glass with a flat mdf front
no probs using fibre glass but they need building up enough so they're strong , so be looking to layer it until 10mm or so
for just a box shape stick with mdf , its strong and dense
I'm going to need to contour mine, so I'm going to go with FG for the back with MDF front. How much do your's weigh? Obviuosly building it up makes it thicker, but how much heavier in relation to say MDF?
its still heavy...maybe 2/3rds of what all mdf would be
id guess its 10-12mm thick with 18mm mdf front
have a look on talk audio..something like this is what I'm suggesting , apart from he used masking tape lol
http://www.talkaudio.co.uk/ipb/index.php/t...-sub-enclosure/
Dead good read that, some inspiration there. Sort of thing I'm looking at. OEM kind of thing.
Does it need to be rock hard? It'd be much easier to stick a thin sheet of high density foam mat over the area to smooth out the shape (or just mould the whole thing in expanding foam and sand down to shape, wouldn't even need to cut the recess out and board it up for that).
