Rusty Wheel Arch
My Drivers side wheel arch is getting really rusty now, so i took it to a paint specialist. He said its rusting from the inside out and it would have to be completely re-sprayed and then blended into the door. He Quoted £250 but a new wing in the correct colour would only cost £110. The colour is LA7W and i was just curious whether a new wing would be better and whether it would look different in coulour without the door blended too? Thanks
  • Views 1.5k
It's not the original wing, it's a cheap pattern wing which has been put on to replace the damaged original at some point, it's made of rust and will just rust out again in no time after being painted again.
The original wing was galvanised. Like the passenger side wing which isn't rusting..
So you want a new genuine VW wing, and a proper job of getting it painted to a good match. As should have been done when the accident damage was cheaply repaired.
  • 4 months later...
Quick question....
I was wondering if it would be possible to hammerite the inside of the wing and then only recondition the flat edge where the rust is? would it work and make it cheaper? Thanks Lewis
You could, the fold will certainly make it easier to blend
I was thinking that the light reflected will be different because its flat (if that makes sense)you wont see the colour difference as much, but i want to ensure that i can prime the whole wing to ensure the rust doesn't penetrate from the inside out again.
Thanks again
Lewis
Edited by Lewis_tdi1.4
It would be quicker and cheaper to get a secondhand wing, there are a couple in silver on ebay around £25
I've looked on ebay for them, but they are either to collect in person, or have damage to them, or say (need a re-spray)
I need one i can directly put on to swap mine, or do something to mine...
Cheers Lewis
