Rear washer
My 6n 99reg polo rear washer don't work do they have a Separate water bottle if so where would it be
  • Views 992
Front and rear both run off the same pump in the same bottle under the bonnet.
Might be blocked or the pipe may have popped off
Same bottle and pump for front & rear, pump spins one way for front and the other way for rear, have a check in the boot area for a flooded spare wheelwell, there is a production break in the pipework just by the rear passenger side upper seatbelt mounting point, on mine this had popped apart and hence the flooded wheelwell, other area would be on the motor unit where the pipe attaches, undo the screw in the trim and pop the cover off,
Cheers matey thank u both off for the info I will have alook tomozz on my day off as I got a bit off body work to do
Can you hear the little washer motor when spraying the windscreen? Should be easy to hear with the engine off.
Now can you hear it when spraying the rear screen? If so, the pipe may be blocked or split/detached somewhere as said above. But if it's silent, then there must be a break/ fault in the electrical circuit (switch/wire).
Cheers matey for that info I will be having alook tomozz
i had a look when i press the rear washer button i can't hear the motor work but the washer works when i use the front ones so i can rule out motor so i must have a broken wire somewhere so if anyone can help with i would be very greatful
Replace the wiper arm/stalk assembly
