the how to guide to mk4 bonnet struts
i hunted for ages on the net trying to find out how to do this and had no joy, there was a few hints and tips but nuthin that was a step by step and to be honest its the quickest and easiest mod I've done to date haha.
went to scrappies and took these from the tailgate on a mk4 golf
removed the top bolt from the bonnet hinge and the wing bolt just at the rubber bonnet rest
had to make the hole a tad bigger to get the bolt to fit but all is good :)
then fitted the strut and it holds the bonnet up fine
the pic shows i have one on either side but i would advise against this as 1 is defanitly more than enough i ended up removing one.
its a great mod and i think it finishes it off a bit haha, hope this helps anyone that wants to do it in the future.
  • Views 1.5k
Lovely, i have them lying around in my workshop. So gona do the same thing :). Thanks for guide
  • 1 year later...
Did you have any problem with the bonnet not shutting properly? I done this today and noticed that the bonnet isn't closing properly on the side of the strut exactly where it is. Other then that its perfect!
