Water stain on roof lining
Was cleaning the 6n2 out yesterday and noticed a stain in the corner of then roof lining (and obviously feared the worst) so I pulled the trim off in the back and under the capret is all condensated and wet, and I was wondering if this red tubing was the sunroof drainage or not? If not what could be causing It the leak?
  • Views 1k
Worse than I thought , both sides are like this! Seems weird how both sides have gone, thinking it might be the aerial gasket? Anyone ever had this problem?
If it's the aerial gasket, tends to pool right underneath. If it's tatty - replace (£4 eBay).
Check the rubber seal around the bootlid carefully for leaks and or wear.
PoloD.
I've not long replaced it but I don't know if I've done something a miss like put the gasket on right etc. yeah checking the seal is my next move making sure it hasn't moved away from where it sits,
Boot seal looks good, may have come away from the sitting position with time and was rather dirty so I've pulled the top off and cleaned it all out and run a bead of silicone around the top of the seal so I'll see what happens
