Full mk3 golf seats in mk2f polo.
As above?
How to modify the frames?
Any guides on how to make the frames narrower or is it easier to get some corrado/roco subframes and put them in?
Any one got mk3 golf split rear bench to fit in a mk2/mk2f?
Thanks,
Beinn.
  • Views 1.9k
the front seats just require a hammer:-S i sold some seat ibiza seats which are the same fitment and he did just bash the legs in a bit. the proper way would be to cut and weld the legs in to the correct length.
Can't help with the rear bench- but after doing the TT stuff id say find a split polo bench and retrim it.
Just wonderd if some one had put the effort in before?
Anyone put Golf mk3/6n/6n2/Ibiza seats in to polo mk1,2,3/mk2 golf?
Laid the rear bench on top of the polo one the other day, bottom bench should be the easyest bit.
This interior has to go in my car no other way about it.
Do your rear seats split? As I think the golf ones do? Do for the upright part, you would need the centre pivot bracket. Not sure I'd there are pre tapped holes in the floor, so thou may have to drill and bolt it to the floor, or weld it in?
Then there is the matter of the latches, not sure if they will line up. You COULD, at least in theory use the current backing metal and fit the seat foam from the mk3 upright to it. Then, cut away the sides that go where it splits and have it sewed together, making it a single bench, which will fit right.
The lower part you may have to swap over the frames under the seats toallow them to hinge.
Front will need the legs sueezing a bit, hammer should do it, but best to remove the white plastic bits from the runners before doing this.
Hth.
