Water getting in to central locking box. Polo mk4
Hellooo :)
My polo mark 4 has a leak in the boot. Water is getting down the leads and into the vacuum pump box that operates my central locking. Does anyone know of common places where this water may be getting in as every time it rains hard i have to take it out and dry everything to get the locking working again. I know that this wont be the case eventually if it keeps getting wet! The break light at the top of my hatch is loose and doesn't sit fixed anymore. Could the water be getting in there and working its way down? I honestly have no idea..
Any help would be great :)
Thanks! Nick
  • Views 833
It could do yes, but I'd put your problem down to a cracked light or bad light seal.
My 6n2 had the same, I popped the light out and siliconed it back on, but found my aerial gasket was letting water in and it was running down the c pillars which wasnt helping my cause haha.
Mainly the light seals are not sitting flush, and letting water in.
Boot sealmigg be perished?
If you have a sunroof then then there is two pipes that run down the c pilar, this can be loose or broken.
The seal around the aerial is no doubt perished (most are) and will need replacing.
It could be coming from the brake light, but this would normally leak into the boot, rather then the lower c pilar, so it needs spring but I doubt it's the caise.
Most common is the light seal really. Silicone sealant will fix it nicely.
