1.3 gt engine.. will i need loom and ecu?
bought a 1.3gt engine off Jim (runforestrun) on here and was just thinking
will i need:
gt engine loom?
gt ecu?
its on b'carbs if it makes any difference?
Sam
  • Views 657
Ideally the loom yes so that the clocks still get the readings from te sensors unless your using your old engine loom and not binned it
And no you don't need the ecu as long as your running the mk2 ignition system
yeah i will keep the standard loom in and thats good about the ecu :)
just a thought as i get a bit closer to putting her in! dont want to get to the end and be like WHY NO WORKYY!
will i need:
gt engine loom?
gt ecu?
Sam
For bike carbs? no you just use mk2 stuff
