mk2f heating problems
i didn't know if interior and trim was the appropriate forum to post this in haha but yeah my heating is fucked. The fan speed works just fine with no problems, but the direction of heat and the temperature dials do nothing. so it is just always coming out freezing cold (even though the dial is turned to hottest setting), and i can't change it to de-mist or point at feet or just face or anything. Both of the dials are very very stiff to turn, and there is a clicking locking sort of feeling when i move them from where they are currently sat (5-oclock if you imagine them to have clock faces) - then after the click/lock they just turn stiffly and there are no other clicks or locks anywhere, and when pushing each dial to the other end of the dial (7-oclock) it becomes extremely stiff as if it is going to snap and then upon release it very shortly turns it's self back round - literally the tiniest bit like 7 to 6 oclock. as if something is battling against it, or i am bending something on the inside and when i let go it unbends. Then when i turn it back round towards 5-oclock it becomes easier to turn and then has a slight click/lock. can anyone help? is there just something unplugged or not sat properly, or do i need something new? thanks!
The face vents will always blow cold air (unless the heater box has been modified) regardless of temp or blow position.
You need to remove the control panel inside the car and check the state of the wire adjusters on the back.
The temp control is connected to a small valve on the right hand side of the blower motor, check that this moves freely.
The selector is connected somewhere down the back the centre of the dashboard (you will need to follow the cable), check that this moves freely.
aaaah right, i feel like such an amateur now :oops: and thanks ill have a look tomorrow and be in touch :)
the motor housing does come in two parts as well, might be worth checking that the heater matrix isnt clogged with leaves.
