Drivers door catch jammed.
Went to get in the car this morning and the driver door catch is jammed. Had to climb across the passenger seat to drive the thing.
It seems to be unlocking and previously I had noticed that it was a bit sticky to open.
Any recommendations on how to get the door open to inspect the catch as it's a bit tricky to get the door card off when it's shut?
!m!
  • Views 811
Hmmmm...
And it works again. Must have been frozen this morning.
Bit weird seeing as I've driven it in much colder weather. A coat of oil and grease later is in order.
!m!
Lube it all up, and if necessary adjust the latch by slackening the bolts on the b polar and hold the handle open then shut the door then tighten slightly then slam the door, tighten again then close normally if it's not 100% then loosen and tap gently then retighten
Hth
