Oil control/retention ring for ABD/GT/AAU engine
Long story short, my sausage fingers + shit spring compressor have snapped 2 of my oil scraper piston rings,
The engine code is ABD, though 3F (GT) piston rings are the same, as are the AAU.
If anyone has any good condition second hand ones laying around i'd gladly take them off your hand ASAP.
In real need of these now.
  • Replies 14
  • Views 602
Oooh. Good luck chief, these are hard to come by. However, I have 2 sets of used, both still on the pistons with one set still in a block. You want me to have a look? Won't be for a while I'm afraid
Messaged you si!
unlucky Max i dont use the piston ring pliers for the oil scraper bottom rings only the middle and top rings as its alot easier and the oil ones are so thin and fragile at the bottom as I'm sure your now aware
good luck
There was no problem getting them on, its getting them into the bores without them breaking!
Weve had three of us try now and every time theyve broke, both very experienced engine builders.
The rings have been gapped correctly, so go into the bores fine. Its when they have the inner spring fitted that they start breaking.
thats real unusual :/
i take it your using the piston ring compressor tool for fitting the pistons into the block i know there are other ways of doing it but i bought a compression tool for like £8 delivered and works perfect
Do you mean the tapered sleeve approach? we machined one up, and they still crumbled.
I'm not saying there's something wrong with the rings, but i'm pretty sure we're being as careful as possible!
No I'm on about the special tool you can get which compresses te rings into the piston causing a parallel sleeve around it then you just slide it down into the bore
Aye a piston ring compressor. Have two, one old and one new. Both same outcome.
Either snaps the oil scraper, or fails to compress it enough.
Tried the tapered sleeve and they just snap.
Oh right I dont know then mate hope that don't happen on my new pistons as the rings are hella expensive
Where abouts are the rings snapping is it when they start going into the bore then
Edited by StinkyPete
Theyve snapped at all different point in installation mate.
Takes the piss!
they're fine when placed into the block on there own. Gapped fine etc
Then with the addition of the spring ring, and the piston, they just break :(
If your still after some rings Max theres a chance I might have a second hand set, I stripped a AAU block which had holed a piston, I think I've still got the pistons/rings etc, I'll let you know
found the full set of pistons and rings if you still need them
Hey will, how much would you want for the ring?
pm'd you
