6n2 Outside Temperature Gauge
Where abouts is it located? Can you get to it by taking the cowling off?
  • Replies 33
  • Views 6.8k
Yes, or the radio feed, that's closer.
The radio is closer but the lead from the ignition switch is as near to being a direct feed from the battery and therefore the least likely to be affected by switching loads on/off as it comes direct from the battery via an 80amp fuse See diagram
Right, thanks, will have a go when i get chance!
Sorted now thanks guys. Eventually found the wire (there were a few yellow/black) just traced it back from the ignition barrel.
Just to help anyone else out.
The wire above (blue wire attached to it) can be used as a switched live for many things, e.g footwell lights, just remember to fuse it!
ooh i like it, might have to add this to my ever growing list lol
Pretty simple to do. Looks nice as its blue so it matches the rest of the dash
Thought about putting another one in for the inside.
Thought of that but i didnt know where to put it and looks a bit naff
