WANTED: Cambelt covers for 86c style engines (GT,AAV,AAU,MH etc)
As title, mine are goosed!
Edited by MaxGT
  • Replies 9
  • Views 548
Think I have them. I will have a look. Yours for free if so :thumbsup:
Legend. Will PM you mate.
Anyone got any that could send them ASAP?
Have managed to get the lower, and upper outer one.
Has anyone else got the upper inner one? The one that bolts to the head.
In real need of it now!
I might have a upper inner cover max, ill have a look up the unit tonight
if your proper proper in need I've got a couple in the unit you can have, just replace with another whenever you can
Thanks will, is there any chance of posting it if you find it?
Cheers saf, if will can't post. i'll see if Matty could drop by and pick it up?
yeah no bother dude
Found it max, its not bad, thers no metal spring clips with it, but where they clip in are all intact, all of the metal dowels that hold the cover to the head, water pump etc are there, timing mark is intact. theres a very small crack at the bottom which you wont notice and the small plastic casting which bolts to the front of the head, is snapped. up to you u still want it? I can post too
