Boot lock jamming. Advice please?
Hi guys.
The boot lock on my car keeps jamming. Its been a problem for a while, and takes excessive 'play' working the key in the lock to it to open/ close (the barbell doesnt turn when turning the key).
Not sure how to go about this one. Taken the panel off from the inside and outside of the tailgate to take a look, but cant really get access to where it seems to be jamming. Sprayed ,loads of wd40 inside too but hasnt made a difference.
Anyone know how to go about this problem? Advice would be a huge help!!.
[sorry, need to reiterate that this is for a Mk2f polo coupe. Boots jammed shut!].
Edited by Nick_593
  • Views 994
You can remove it all and clean it up and lube it etc.
Firstly remove the plastic trim cover, then pop the linkages off from inside. Then undo the two Allen bolts and remove the wiring and then withdraw the latch.
Then undo the two torx screws holding the hanlde mechanism in and lever the clip off the barrel and withdraw it then take the handle off. Then carfully take it all apart and note the order, then clean and lube it all up. Then put it all back.
Is the outside of the handle cover have any corrosion on it? As mine did and basically the whole thing was corroded and couldn't be used again.
Hi mate is all this for a Mk2f??
My bad, totally didn't even occur to me to ask. It's for a 6n/2.
I have read that it's also common for the cylinder to corrode on them too, so removing, stripping (the lock :) ), cleaning and refitting will no doubt dot it out. Although I havrnt done this personally so I am unsure on how to go about it. But I am sure it is a similar design.
Cheers mate. Found a thread on here to sort it out!.
http://www.clubpolo.co.uk/forum/index.php?showtopic=243094
