Stretch and lows. Legal?
Hi all. Had a bit of a run in with the old bill again regarding my car. The officer was a traffic branch officer but was off duty at the time. He said if he wasn't and he had his paper work he would've seized my car at the roadside. So he gave me a days grace to change the car and put it back to standard.
Basically he said the stretch on my tyres was illegal and dangerous and that the tyre could pop off at any second. Now I've had the tyres stretched for around 2 years and never had any issues with them coming off. He also said the car was too low and therefore wouldn't handle correctly. He said when I hit a bump my car left the surface of the road (which I belive to be nonsense as I think I would notice that)
I'm just curious as to what the legal limit is for stretch and lows as I've talked to tyre fitters in my work and they say in regards to stretch there is none. Car is still standard and it's doing my nut in trying to drive it. It handle worse on the Standard pram wheels than the banded steels
  • Replies 26
  • Views 4.4k
what were the details of your setup, pics etc?
its a grey area, but if you car looks ridiculous llike half of the scenester kids, it no wonder the plod take exception
There is no legal limit for lows.
Legal limit for tyres is within manufacturers specifications. For example Bridgestone recommend 165/50s up to a 6J, anything over is technically illegal.
You mean it's technically legal... just not recommended.
No, because if it's outside the manufacturers recommended limits, it's illegal. Pay attention.
technically illegal - really?!
Wheres your source for that information, as I've got a feelign your chatting shit
Reference sources
https://www.gov.uk/vehicle-maintenance-safe...cle-maintenance
Tyres. Tyres MUST be correctly inflated to the vehicle manufacturer’s specification for the load being carried. Always refer to the vehicle’s handbook or data. Tyres should also be free from certain cuts and other defects. Cars, light vans and light trailers MUST have a tread depth of at least 1.6 mm across the central three-quarters of the breadth of the tread and around the entire circumference. Motorcycles, large vehicles and passenger-carrying vehicles MUST have a tread depth of at least 1 mm across three-quarters of the breadth of the tread and in a continuous band around the entire circumference. Mopeds should have visible tread. Be aware that some vehicle defects can attract penalty points.
Law CUR reg 27
This is from the British tyre association, they haven't stated a particular law that deviating from the original fit tyre, but infers that your vehicle must be safe (as it is your responsibility as a driver to ensure a road worthy vehicle)
www.btmauk.com/data/files/Replacing_Car_Tyres_1_June_2011.pdf
Deviation from Original Fit Tyre
If changing the tyre size from the original fit, ensure the Load Index and Speed
Symbol of the replacement tyres are equal to or higher than the original fit tyres.
Also ensure the replacement tyre‟s rolling circumference is comparable with the
original fit tyre. It is advisable to check with the vehicle or tyre manufacturer that
the intended replacement tyre is dimensionally possible and an appropriate fit on
the vehicle. It is also equally important the tyre and wheel size are compatible.
Conversion guidelines require that, whether using existing or larger diameter
wheels, replacement tyre rolling dimensions, load capacity and speed rating
match those of the manufacturer approved tyres for the vehicle. A typical
example of not applying these guidelines is the fitting of 195/50R15 82V to a vehicle requiring 195/60R15
88V. In this example there is a reduction in load capacity of 85kg per tyre, possibly rendering it
overloaded/underinflated, and thus, potentially both dangerous and illegal. Furthermore, the 38mm
reduction in overall diameter, and thus rolling dimensions, adversely affects gear ratios, ride height,
speedometer reading and can affect ABS, traction control and pressure monitoring systems where
applicable.
When changing tyre size from the original fit, it is recommended the vehicle‟s insurers are advised and their
agreement obtained, otherwise insurance may be invalidated. Fitting of inappropriate tyres will affect the
vehicle‟s handling, potentially compromise safety and hence render the vehicle illegal.
If you have any sources regarding an actual law that would be broken in putting a 165/50/15 tyre on a 7 inch rim, I'm all earrs
I'm racking my brains now :lol:
Your insurance could quite easily be voided by using tyres outside the manufacturers' recommended limits (have you told them you're running 165/50/15s on a 7J?), hence you are driving without valid insurance = big fat no no. I don't think there's any specific laws around stretched tyres so it's a bit of a grey area, I'll do some digging though.
LOL saf.
crash and burnnnnnnnn!!!!! :lol:
the key word here is RECCOMENDED
i reccomend you shhh but you probably wont
Edited by erixtar1992
Fantastic replies guys thanks:)
Specs on my set up were 8j front banded steels with 155/65/13 tyres and 9.5j rears with 165/55/13 tyres. I'll upload pictures now. As said I've ran the car like this for a few year and never had any issues with tyres popping off. Now it's gti swapped so car obviously is given a spirited drive occasionally and I've never faulted it.
9A2B4E12-9882-4142-B0CC-0D01F8749C7D-366
That's the fronts
That's the rears. Sorry it's not a great photo.
40EC26F2-ACB6-4DFE-9F42-B94BFB8029B0-204
That's the way I had the car when I was pulled. Hubcaps over the banded steels.
Now I'm not here to say someone's advice is rubbish or anything I just want people's views on it as I'm curious as to what the next move is. Since being pulled in and changing it I haven't heard anything from said officer. He said he would be up to inspect the car. So I don't know whether it's a scare tactic or not. He did say if he saw the car on the banded steels again he wouldn't be as lenient. So I not risking loosing my car and going to court over a set of wheels. But I don't want to spend money buying a new set and getting told car is still illegal.
I also want to make it clear that everything in my car is declared on my insurance ie engine swap, coilovers, wheels etc as I was almost buggered a few years back about no insurance on mods and just for away with it so not risking it again
Also as a mechanic all the mods have been done safely and stuff. No half assing. You won't find a cut spring or anything ropey like that on my car
Edited by Lowlow6n2
Motor vehicles approval regulations 2001, schedule 3, section 16:
4. Each tyre fitted to the vehicle shall be of a nominal size appropriate to the wheel to which it is fitted.
http://www.legislation.gov.uk/uksi/2001/25/schedule/3/made
Road vehicles (construction and use) act 1986, part II C, section 27:
27.—(1) Save as provided in paragraphs (2), (3) and (4), a wheeled motor vehicle or trailer a wheel of which is fitted with a pneumatic tyre shall not be used on a road, if—
(a)the tyre is unsuitable having regard to the use to which the motor vehicle or trailer is being put or to the types of tyres fitted to its other wheels;
(b)the tyre is not so inflated as to make it fit for the use to which the motor vehicle or trailer is being put;
©the tyre has a cut in excess of 25 mm or 10% of the section width of the tyre, whichever is the greater, measured in any direction on the outside of the tyre and deep enough to reach the ply or cord;
(d)the tyre has any lump, bulge or tear caused by separation or partial failure of its structure;
(e)the tyre has any of the ply or cord exposed;
(f)the base of any groove which showed in the original tread pattern of the tyre is not clearly visible;
(g)either—
(i) the grooves of the tread pattern of the tyre do not have a depth of at least 1 mm throughout a continuous band measuring at least three-quarters of the breadth of the tread and round the entire outer circumference of the tyre; or
(ii) if the grooves of the original tread pattern of the tyre did not extend beyond three-quarters of the breadth of the tread, any groove which showed in the original tread pattern does not have a depth of at least 1 mm; or
(h)the tyre is not maintained in such condition as to be fit for the use to which the vehicle or trailer is being put or has a defect which might in any way cause damage to the surface of the road or damage to persons on or in the vehicle or to other persons using the road.
http://www.legislation.gov.uk/uksi/1986/10...ulation/27/made
Here's where your grey area comes in, ok arguably illegal is probably a more accurate term that technically illegal.
Happy?
Edited by Koop
LOL saf.
Have another go at spelling it. You're nearly there.
I run 165/50s on a 6.5J btw, I'm not saying don't do it, I'm just saying be aware that if the law want to fuck you for it, they can.
Edited by Koop
Thanks again for replies guys. I can't understand how it's deemed dangerous if it can be driven on ok. Fair enough I understand if you are running mad camber and driving partially on sidewall I can totally understand how that would be deemed dangerous. But it you are running on all the tread of the tyre, the tyre is inflated enough to keep it on the rim and the tyre isn't damaged in no way I can't see how it would be dangerous
LOL saf.
ooooft, you know youve touched a nerve when the clubpolo spelling teacher makes an appearance! :lol:
meh. 165/55 on an 8j.
ps - chill man. only having a laugh no need to get emotional
Cheers Koops (btw no beef intended!)
Yup its just pure grey area, if you get a copper who's had a bad day they might go awol, but to be fair you could defend it in court if anything happens and argue the point that theres no explicit law forbidding the act of an incorrect tyre size on a wheel and you could possibly point towards TUV testing in Germany (part of the EU) and their strict testing.
Obviously if your running tyres above and beyond the TUV regulations, then i wouldnt go using that standpoint haha
:lol:
Likewise mate, just a mild flambé to while away the day ;)
Edited by Koop
to the OP, the car does look a bit ridiculous like, I can see why some coppers could want to stop it.
normally they just give you a vehicle defect rectification notice, you got to the MOT they stamp it, go to the plod station and alls good.
if he didnt give you any paperwork, i would just carry on as you are. I got stopped and issued a section59, no paperwork nothing. As far as I'm concerned it didnt happen, whether the plod have a different idea
^good point.
I rather think you have contradicted yourself in that post.
Mr Plod thinks your tyres are dangerous. He's likely guessing that they aren't within the manufacturer's guidelines for the wheel / tyre combination and he's likely right. If it comes to a court case, someone will have looked up the manufacturer's guidelines and found for definite whether they are outside or within the guidelines. If they are outside the guidelines what are you going to say? If it comes to it, the prosecution will find some "tyre expert" who will agree with their point of view, but the manufacturer's guidelines will likely be sufficient to convince a bench of magistrates that your set up isn't acceptable and is therefore risky or dangerous.
Stretched tyres look wrong and will draw the attention of the police so you're asking to get pulled.
All the police are doing is making sure your car is safe and legal, if it stands out they will investigate, it's their job.
Agree car does stand out and it does attract attention both good and bad. I just wanted people's opinions on how they see stretch etc and if it's legal. And the majority vote seems to be no. As said it all depends on the cop as well. I've had other officers stop me and say nout about thy tyres etc and the woman I bought the car off who is my neighbour her and her husband are both police officers and have never said anything about it and they see the car everyday.
The banded steels are up for sale anyway as I'm not risking another run in with the police and loosing my car
I'm shore with that sort of stretch the tyres are not incontact with the surfurse properley and will be running on the sidewall of the tyre causing the sides of the tyre to get hot at motorway speds that cause the tyre to blow out
I'm shore the specs on those side of your tyres done go up to anything like that with of wheal haveing sutch MAJOR stretch does make your car stand out
dont sell the wheals fit some tyres for that with of rim 225/45/13 in the 9j maybe :unibrow:
Edited by g40dabbsy
Whether its legal or not, i think it looks totally ridiculous. I really cant see what the point of massivley stretched tyres is?! Just buy some wheels that fit, and some proper tyres. I actually dont mind a little stretch, but when you start getting 45 degree sloping sidewalls, and it starts to get dangerous, NO.
They probably don't make it ILLEGAL to fit 165:50's on a 7j because they probably don't think anyone's stupid enough - maybe it should be reviewed.
Tbh most cars are probably fucked legally on here, not sure how it all stands but even things like brake flexi hoses are a pain to get into legislations when building new cars, so when we excessively lower ours and they run at all sorts of angles I'm sure vosa would have a field day.
haha brake flexis are the least of your worrys when spme pepole drive arround with tyres rubbing on bodywork that may blowout on a motorway when there doing some sort of high speed the end result could be faital
