6n2 ach mod for clearance
Okay so I got some new wheels. There 15" 7j with 165-50 tires and 25mm adapters running slight camber. I've had to higher the car loads to get them on and now I want it back down. I've rolled the arches are they are still catching. There was a support bar on the inside of the arch so I chopped/bent that out the way and there still isn't enough clearance... This is what I've done.. Yeahh it's messy but it can't be seen! :)
2CD539F3-3919-4C32-87EC-6BF37F832DA7-601
What's else can I do to get some more clearance? Would consider swapping my 25mm 4x100 to 5x130 (Porsche fitement) adapters to somthing thinner.
  • Views 1.2k
20mm adaptors might help? take the arch lining out aswell completely then roll the arches properly at a bodyshop for about £150
It's not the arches where it's craving though. There is a screw that holds the bumper to the arch and it's there that it's scraping.... That can't be rolled out as it has a surport! Which I bent/chopped out the way
I run BBS RS reps 15" 7j and i have no arch rubbing problems.. Get smaller adapters :)
edit: I also am running 195/45/15 tyres and it still doesnt rub (unless i have lots of weigh ie; 3 people, in the back) .. getting 165's next time :)
I run 15 8j et30 at the front with 195/45 and this rubbed like a Bi**h on that nut that holds the bumper... so much so that it dragged the bumper down. this is something I need to fix lol :( I'm definately running 175/50 this year to go a bit lower.
Edited by Funkyjord
Who decided they'd put the nut there! I'm gonna try and figure a way to get around it tomorrow. Thinking about chopping the nut off and moving it or holding it together with a cable tie! I've just ordered a pair of 165/45 tires so well see how low it copes on them. If all else fails thinner adapters are in order!
