Removing the locks from 6n2 Door Handles
Hi their does any one know how to remove the door locks from the door handles on a VW POLO 6n2.
Cheers.
  • Views 4.7k
Removing is easy, refitting takes a little more patience
Firstly iththe locks I. Front of you (removed from the door) look at the long paddle, at the base of this the is a circular part with a cutout on one side. Using a screw driver lever this to the side and slide off. Be cautious as there is a spring under there, remove the clip, paddle, surround, spring and crown parts. Inset the key into the slot and turn 90° and look through the topto line up the pins with the slots. Then pull the barrel out. Do not remove the key as the pins may fall out. There is also a sleeve which removes from the other side. Clean all these parts up well and lube everything before refitting.
Needle nose pliers are your freind when fitting the spring.also if anyo of the parts are broken then there is a kit on eBay that has all new bits needed.
Cheers and thanks for the help
No worries buddy, give it a go and if you need any help them just post up on here .
