Pannel removal
Rite I'm stripping the coupe down for some work and respray and need a few things taking off..
First off the wings. I've took all bolts off but havnt actually done the ones in arches yet, are they bonded on at all or willl the just pop off after all bolts removed.
Need to remove boot also but i want to remove the glass as there is some rust bubling under the seal and need to fix this .. How does the rear boot window come out ?
Last is the rear windows.. Heard these just push out but a few tips would be great. thanks :)
  • Views 942
I think the ones inside the arches may have some kind of sealant on them but they should just come of I think. I think the winsdow is bonded, so may need special tools to get off in one piece.
Rear windows push out easy, i laid down across back seats and pushed each side with my feet then get a mate standing outside to stop it falling ;) not sure on the rear window... but i have a spare if you break it haha
get a blowtorch and melt the seam sealer on the inner wing bolts, otherwise when you take all the bolts off and pull the wing off you may be likely to bend the metal as you peel it to break the seam sealer.
cheers guys..
Haha yeah rear window is the main one I'm worried about :/
rear window on a mk3 is bonded I'm pretty sure, i tried to remove one from a smoothed bootlid many years ago, shattered it (in my bedroom of all places) and ended up with shards in there for weeks!
Does the headlining have to be peeled back to access the boot bolts ?
