Do 6N door cards fit 6n2?
Like the title says.. (might sound stupid but just thought i'd check).. Do 6n door cards (3 door) fit on 6n2 doors? is there a way of making them fit?
  • Views 952
They will physicly fit as they are the same shape etc, but you will need the tweeter as well and the metal bracket as it uses it to hold on.
But, they will not line up with the 6n dash AND the window switches are in the dash and will need moving to the doors.
Ahh quite a lot of effort then :/ Thanks man!
I think I was on the piss when I read your post, you want to put 6n door cards onto a 6n ? This should be easier because you don't need the bracket, so just remove it or fit the card over it. The speaker might not line up, but it shouldn't be too far off.
