Drilling Spot Welds - MK2
Anyone know the bit size required for a spot weld drill on a Mk2? Need to remove the front panel from mine and don't want to take more material out than required
  • Replies 11
  • Views 1.4k
drill it out then nut and bolt it like a mk2 golf :p easy access!
That's what I'll be doing, but I don't want to drill more than I need to
spot weld drill bits are 8mm
Luke
Luke
yeah..get a proper drill bit, plenty on ebay etc
Yeah, I've seen them, but they come in 6mm, 8mm and 10mm flavours. I went for an 8
fair play!!
can you not grind through them? or is access shit?
I want to try to keep the front panel mostly intact. Although it's damaged, I have plans for it in the future. I'm not sure about access either, but Kerrly seemed to get his off ok with a chisel and ting. I think I shall be ok drilling them out, there's just loads of them!
How did you remove your slam panel Eric?
i just drilled it with a drill bit that was slightly bigger than the spotwelds
Where are the spot welds? I have the thatcham repair guide and it looks like some are under the strip the wing mounts too
yeah theres a lil 90 degree sorta bracket. u can sorta get the drill in there.
if not take the wing off and u can get it
Wing off? I'll be doing that anyway, so that should be easy. Any pictures of your old one?
