door refitted somehow locked it solid :0
Hi, I've just had a top gear 'oh cock' moment.
Basically I removed the lock and handle of my passengers door. I ended up sending the handle off to express auto keys who did me a nice set of two keys for £30. Can recommend them.
The problem is on reassembly of the passengers door I closed it and I've somehow deadlocked it. The lock on the interior is in the open (up) position.
I'm guessing I'm buggered with it really, but surely there is some way to fiddle with the lock from the inside of the door?
Peter.
  • Views 868
if you remove the door cards you can see the paddles that lock and unlock the door. chances are its not in the correct position.
