flimsy bit of plastic between front and back windows
I'm not a big fan of the bit of plastic which is glued into the space between the front and back windows on the polos, if you know the bit i mean? it's like a flimsy bit of corrugated plastic on one side, then just a flat textured bit on the door.
I'm thinking of peeling it off, but don't plan to respray the car any time soon - how well is it stuck down? would i easily be able to get the glue off, or would i regret taking them off?
  • Views 1k
Use a hot air gun and slowly pry it off, provided you melt the glue they will come off without ripping paint off, then use a solvent to remove it, I used isopropyl alcohol to remove the glue residue from the rub strips, worked fine. Don't be tempted to use acetone because it rips paint off too.
okay, thanks for your advice - is this a time consuming job? not sure whether to do it soon or to wait until after deadlines! haha
post up how you get on ...been thinking of taking mine off too
will do, might not be for a while though
I just pulled mine off, no hot air or anything. I then used a toffee wheel and bit of panel wipe to remove the excess glue. No drama or paint removed.
is the whole area glued or just the odd bit here n there
IIRC (it was a few years back) any area in contact with the body work had adhesive on. They came off very easily and I even sold them on as they weren't damaged. I found mine had started to lift ever so slightly on the door shut, so i started there, peeling all the way down and then working my way across in a diagonal pattern
Edited by prankstar2003
