clay bar kit ... worth it?
Hello all!
Been contemplating getting a clay bar kit but don't really know if its worth it?
Does it make much difference to those that have used one?
Sam
  • Replies 18
  • Views 1.5k
Yeah they are really good when used with a good polish and wax but its quite a lot of work but the results are awesome
As above, really good results if you spend the time doing it properly. I'd say a good whole day for job lot and it'll look immaculate
if i was you i would wash your car dry it off and feel the paint with the back off your fingers.
your feeling for any fine grit/dirt that normal washing dose not remove.
by claying your car you remove any wax and polish.
once clayed it should feel silky smooth :-D.
hope that was off some help :lol:
definately worth it, when i got my car it had loads of little tar spots or bits of grit that you could see up close, normal washing or polishing couldn't get those out, but the clay bar soon sorted it out
Yes...
Yes it picks up so much off of your paint! If you want some guidance on how to use it google detailing world and there is loads of guides on there! Just to warn you if you don't really know what you're doing you may just end up rubbing grit all over your paint and leaving marks all over the paint.
Bilt hamber clay + dodo juice born slippy clay lube is a good combination
I've got the kit made by t-cut and it works great!
need to wax after tho otherwise it dont last very long.
definitely worth doing, you can actually feel the difference afterwards think I only paid like 15quid for my turtle kit
but as others has said set aside some time to do it properly and wax afterwards
Sweet thanks for the great replies!
Halfords had a meguires one on sale cause the box was damaged
never bought one before just missed that bit out, usually compound, polish, wax, resin
thanks men!
Make sure it isn't cheap because it has no clay lube
Most clays you can use just water as lube or most quick detailers like demon shine
Fall out remover, clay, paint cleaner, compound, polish, seal, wax....beaut.
Worth it. Will remove paint contaminants and smooth out the finish in prep for polishing and waxing so it goes on easier, looks better and is less likely to screw your paint by removing all the crap on there that causes marking and eventual oxidisation. Just be sure to lubricate it with clay lube or detailer, water works but not a good idea as it doesn't provide quite enough lubrication to slide over containments which can result in paint marring but if you buy a kit it should come with stuff. Would definitely say to get a kit and give it a go, if you're not keen on doing it after trying it then there's no need to do it again, a lot of people don't even bother doing it at all but if you don't try, you don't know (:
I did it on my Lupo which I always keep clean but it was amazing how smooth the paint felt afterwards.
It is well worth it, mask off half your bonnet, just flaying one side will likely make a big difference let alone before paint correction.
You'll find a lot of professional detailers will clay even brand new cars
I got round to using it this weekend ready for a show and WOW!
i thought the paint was clean and smooth but it pulled out loads of crap, sounded like it was sanding it in some places!
lovely and shiney now after a paint correction, polish, super resin and wax ;)
Thanks for the help!
Worth it dude, just generally makes it a lot cleaner
I did a post on my first time using one In the fourm so please feel free to take a look at the results but in short honestly they are brilliant my polo looked so so much better
