One for the Painters
Decided to paint the covers of my mirrors, flattend back with 400 then 800, degreased with panel wipe, then when totally dry applied white primer from a rattle can 3 or 4 coats first & second coats were just a light dusting allowing 1hr between coats, left them to dry off in a warm dry area overnight, then this morning found this on just one of the covers
  • Replies 13
  • Views 1.2k
Looks like the primers reacted to something on the plastics ? Maybe missed a spot when preping. Did you use plastic primer ? its unlucky probs have to start again :/
grease still present. i find washing parts like mirrors with fairly liquid applied neat to the plastic, then washed off with clean warm water does a good job. once dry, wipe over with a panel wipe and paint
I did'nt use plastic primer as I did'nt take the original paint down that far, just flattened it, then de-greased it with panel wipe
Have you ever polished the mirrors with a silicon based polish? Paint won't stick to that at all
Don't know as they are second hand, but if they had been the other casing has'nt reacted :?
prob some shonky paint underneath , sand it all off and start with a plastic primer
I've been told that can happen with the paint underneath and the paint you are using reacting. You will need to use a blocking agent or take it right down first.
Hi there. It looks like a paint defect called crazing, i would reccomend that you wash the primer off with thinners, you may find that the paint underneath the primer may also come off, as it may have been done with aerosol in its life, basic rules with paint are paint over aerosol and you have big reaction problems, wash off aerosol and apply paint gingerly and happy days, hope this helps and if still no joy PM me and ill be happy to help :)
Well it might not be the correct way of fixing it :? I could'nt face removing all the primer and old paint, so I used a deremel to grind back the cracks, then filled with P38 flattened it back and two coats of high build spray primer and it's looking OK
Another Question, with the high build spray primer, is it best to wet or dry sand? as I've heard or seen somewhere that it will absorb water???
Ok, slightly odd way of putting it right. But if it works.
Really doesn't matter which in my opinion. I pretty much always dry sand, but occasionally wet. It is true primer is porous. For the sake of wet flatting, won't do it much harm.
Out of curiousity, why did you leave an hour between coats? In my eyes that's far to long inbetween coats. If the coats are put on light enough and built up gradual, you could get away with 10-15min flash off (less if your in a warm environment)
The only reason was I left them to dry in the bathroom (warm and the extractor fan to get rid of the fumes :lol: ) and it was about an hour or so between needing a slash, so had a slash and gave them another coat :lol:
I'm guessing its problem solved now?
But this comment is epic ! Painting in the bathroom! 8-)
That can happen if you have put to much paint on and then tried to dry it too quickly.
