door panel removal help
guys, can anyone tell me how to remove the door panels from a 96 plate polo 5 door.
i have only managed to get the door handle cover off.
how does the window winder handle come off?
i take it the rest is just clips and you have to pull off?
thanks in advance.
  • Views 852
Unscrew the locking knob
Remove winder handle
Removing
– Push spacer ring -2- in direction of -arrow- (releases securing clip) and pull window crank from drive
Then the trim should pull of the clips
Refitting the winder
Installing
– Clip window crank onto drive in locked/up position.
The installation position with window closed is -a- = 45° ± 12°.( 10:30 position)
brilliant mate, worked a treat. Thanks
