Mk3 Polo Front driver door stuck shut
Hi
I have a 1998 Mk3 (MN6) Polo 1.4CL, which has central locking and electric windows. The driver's door is stuck shut and it's window does not work. The front passenger door is also stuck shut but it's window does work. The central locking pump appears to be working ok. The door lock operating knobs rise and lower when I operate the locks, but there is 'no feel' to the inner or outer door handles and they don't release the doors.
The car battery condition seems ok.
I have managed to open the front passenger door by pulling it's door handle while turning the key in the lock. But I can't open the driver door whatever I do.
I don't think I can remove the driver door inner panel while it is shut.
Please can anyone suggest a way forward to fix this problem?
Best regards
David
  • Views 2.5k
I had to do this with a Lupo but the locks are very different on those. With the Polo there is a relay paddle from the lock barrel to the mechanism, this is very brittle cast alloy and the paddles break.
To remove the door trim the seats will have to be removed.
Thankfully the door released by itself a few days later. I have taken the inside door panel off but need to remove the inner lining to get to the door mechanism. Please can anyone give me some tips on how to do this?
Best regards
David
Check the handle itself out, 1x torx screw on edge of door
Hi
The front door mechanism has now freed itself. I have removed the inner trim panel from the door. I have also removed the external door handle. The handle's paddle is not damaged and the whole of the handle mechanism looks ok.
I am not sure what to look at or do next. There must be a weakness somewhere that is causing the door lock mechanism to jam shut sometimes.
Should I spray everything with WD40 or graphite powder?
Should I remove and inspect the door lock mechanism? (that looks a more difficult job).
Any suggestions what to do next would be much appreciated.
Best regards
David
