Anybody have problems with cv joints?
Right I have a 6n harlekin with a gti lump, subframe and suspension,
Everything's been fine until I fitted the ronal turbos, she chewed up a cv joint on Thursday night so I bought a second hand joint as I couldn't wait too long for the new one to be delivered, 20 miles down the road and the new cv starts popping, I thought it was just a coincidence buying a 2nd hand one that was probably fucked, so I've fitted the brand new joint, same thing. 15 miles later she's knocking.
Any ideas? Am I too low?? Anybody else had these problems?
  • Views 888
Sounds like the gearbox's output flange and hub's bearing face are the wrong distance apart. The joint does have the ability to adjust reach a little, but we're talking about 10mm.
If the engine isn't sitting quite right, it can be far more likely to pop joints on one side. Given yours has had the engine swapped out this rings bells. I know the 6n2 GTi has a different upper gearbox mount than the 6n engines, i don't know what else could be the issue there.
Some adjustment is also in the suspension, such as the two M12's that bolt the hub to the strut, and the three M8's underneath that bolt the ball joint to the wishbone. Those could give you 5mm, but i'd look at engine position first (such as spacers put in the engine mounts to lift the vulnerable ally sump, something a few people have done with heavily lowered cars).
I have a 6n2 GTi driveshaft with good inner/outer joints on it i'll sell, or a joint seperately from it, it's the driver's side but the joints fit both sides. I don't see it'll help if yours is eating them for an above reason though.
Has the subframe been out of your car?
Thanks for the help, I've put the helpers back in for now and she seems fine, I'm looking at ioptioms to raise the engine, and yes it has a 6n2 gti subframe too.
