Vw polo 9n Locking wheel bolt sizes?
Right I've done a search for the size's of a set of locking wheel nuts. Keep seeing the spline set, Just after conformation these are the correct figures.
M14 x 1.5 (14mm) thread size
Correct 'Radius' (round shaped) bolt seats
Correct 17mm spanner/socket size
Appreciated
Have my eyes on these 1's
http://www.ebay.co.uk/itm/NEW-GENUINE-VW-A...=item4170ce2440
Edited by LiamMk6Polo
  • Views 6.3k
they don't look too secure, i'd avoid these as they use a universal key and unless the bolt holes in the wheel are really tight, they look quite easy to remove.
i recommend looking for locking bolts with a rotating sleeve and a unique key as they are a bit harder to get off.
Just want something to protect my bbs from getting stolen :/
When I go to tps ill see if they have any in.. :)
Liam you know how youve put (14mm) in brackets i assume youy mean the diameter of the bolt? dont know if this helps at all as you probably know already but the standard bolts are 27mm in length i believe
