mk2 1986 1.05 breadvan - blue - breaking
now taking lowball offers on everything. getting scrapped within a week!!!
the only thing wrong with it is that the cambelt went and bent a valve. in a true bodging effort i tried hammering the valve straight again with the pistons but didn't think too much about it and I'm sure most of them are now bent. so everything is up for grabs but the engine block and head probably isnt worth taking. i will be keeping some bits for my new one but let me know what you are after and i can get pics etc.
would let it go complete for someone looking to do an engine conversion but my insurance wouldnt allow it for me.
here is the advert from when i bought it
http://retrorides.proboards.com/index.cgi?...p;thread=139032
located near felixstowe, suffolk
parts taken/not available
radiator
fuel tank
tyres - it now has a set of standard steelies on it. tarantulas can be available if wanted without tyres
cig lighter
battery
parcel shelf - now has a saggy grey one but could be fixed with a bit of wood
front grill
Edited by lobbster
  • Replies 61
  • Views 2.3k
i need the screw covers from the dash fixings, they're
about 10mm x 20mm, 4of. 1 either end and 1 either side
of the stereo housing.
ill check i have all four and get back to you. Probably wont be until saturday though
no problem, gives me a chance to see if i need owt else.
can you tell me petrol tanks small or large???
Fuel tank is going in my other car this weekend. Sorry
Wheels, n/s front wing, n/s rear light?
Side trims, just the 'POLO' parts (next to the banana trim). How much posted? Cheers
the tarantulas? that wing has a small dent in the arch. both the front arches have been rolled too in anticipation of some new wheels. You wont have problems with the tarantulas. The light is all good. Do you just want the plastic lenses?
I'm guessing postage will be about 4 or 5 quid so 12 posted?
oh ok
i have a large tank but need a smaller tank for racing to save weight#
oh ok
i see was tempted to ask you to swap but realised i never put more than 25 quid in mine anyway.
if you can weld then you can have my other one for the postage cost. Has at least one hole in the filler neck. but the tank is fine. Not sure if it would be safe to weld it though with the fumes etc. How do i know if its small? It isnt the full width of the car... About 30/40cm is gap between the end and the sill underneath
What colour is the roof lining in this car?
oh ok
the large tanks go over the top of the handbrake cable and have i believe 5 ribs on top
this is the underneath
smaller has 4 ribs and does not go as far
this is underneath
i might be interested in old tank
Edited by series2
yer just the plastic lenses, how much for the light and the tarantulas?
The light has gone now. 30 quid for the tarantulas without tyres
i have all four of these. quid each? 6 posted?
10 posted?
its like a beige colour and absolutely mint!
Have u got the handbrake cable connecters? Brackets for the rear axle?
Do you mean the two rectangle block things?
Yeah they the bits, u got them?
yep. 8 posted?
whats the carb like? is it manual choke or auto?
I'm after the two pieces of side trim just before the rear arches posted. Cheers
[/quote name=VeeDub94' post='2494951' date='Thursday 28th February 2013 - 12:35pm]Side trims, just the 'POLO' parts (next to the banana trim). How much posted? Cheers
10 posted?
Just seen this mate, il have them. You going UD? May be easier than posting
I'm hoping to go but its still a maybe so want to wait and if i dont make it then ill post them on monday?
Alright no worries mate. Let me know if you do :)
