mk2 1986 1.05 breadvan - blue - breaking
have you still got the middle section of the exahast and if so how much posted to luton and would it fix a mk2f bready
  • Replies 61
  • Views 2.3k
I have it but it has a flat bottom from scraping. no holes but it has definitely contacted the floor a good amount. I'm not sure about fitting a mk2f but i assume it is the same. I can't sort this out in any kind of hurry though because i dont really have anything to lift it high enough to get under at the moment... when do you need it by?
na its fine bud as its got flatten lol I'm after a decent one lol
the only thing wrong with it is that the cambelt went and bent a valve. in a true bodging effort i tried hammering the valve straight again with the pistons but didn't think too much about it and I'm sure most of them are now bent. so everything is up for grabs but the engine block and head probably isnt worth taking. i will be keeping some bits for my new one but let me know what you are after and i can get pics etc.
would let it go complete for someone looking to do an engine conversion but my insurance wouldnt allow it for me.
here is the advert from when i bought it
http://retrorides.proboards.com/index.cgi?...p;thread=139032
located near felixstowe, suffolk
parts taken/not available
radiator
fuel tank
tyres - it now has a set of standard steelies on it. tarantulas can be available if wanted without tyres
cig lighter
battery
parcel shelf - now has a saggy grey one but could be fixed with a bit of wood
front grill
Do you have the bolts for the metal cam cover?
radiator
fuel tank
cig lighter
battery
front grill
yes. which ones are you after?
radiator
fuel tank
cig lighter
battery
front grill
The ones that hold the two halls together
radiator
fuel tank
cig lighter
battery
front grill
radiator
fuel tank
cig lighter
battery
front grill
Halfs* sorry
I'm after the two pieces of side trim just before the rear arches posted. Cheers
It's not the two pieces of trim with the polo logo s but the two pieces after it, the ones that go up the arch about 12 inches long. Need both sides, cheers
radiator
fuel tank
cig lighter
battery
front grill
Halfs* sorry
the two on the back side? they are like wood screws with a bolt head on and a washer built in?
the ones that look like boomerangs? one is snapped and the other is sold. sorry
whats the front drivers side wing like and interior and postage on wing to kent, kings lynn or derby?
the wing has had the arch rolled. didnt heat it beforehand so a lot of paint has flaked off but wasn't long ago so probably just some light surface rust. other than that its all good...
as far as interior, do you just want seats or are you after door cards and carpet etc? none of it is in the best condition with a fag bur or two and the drivers bolster in pretty wasted although not uncomfortable. below is the interior i am selling (its from my other car as i will be nicking the interior from the blue one)
http://volkswagenownersclub.com/vw/showthr...ck-90-000-miles
How much for the drivers side banana trim? if its in good nick?
Si
Gone, sorry
How much for front and rear bumpers, glove box, radio and rear wiper motor?
glove box is a bit odd. ill get a picture but if i remember right the tob on the right that the screw goes through looks a bit bent. ill check and see if its just the way its sitting or not.
there is no radio
will you be picking them up?
there is no radio
Please send me a picture if you can. I cannot pick it up I'm afraid, how much would do it for inc. P+P?
how much for the brake fluid reservior posted?
cheers
Si
Alright no worries mate. Let me know if you do :)
still want these? they have been sat in the back o my car for ages now...
Hello mate, i need part of the drivers door locking mechanism. My lock works fine but I haven't got all the bits to make the door pin work.
If you can sell me that mechanism for a reasonable price id really appreciate it.
JC
Its yours for a couple of quid and then postage. do you know which bits you need? i could just whack some bits in the post but i wouldn't want to miss anything... i haven't looked at the mechanism really so forgive me if its just the one bit
the screws you can see, to hold both halfs together, how much posted mate?
Cam covet and screws have gone now unfortunately
Thats brilliant mate, there is really one bit I need. Basically its the nylon connector which sits on a leaver coming out of the lock, the rod from the door pin clicks into the nylon connector. Thus allowing you to operate the lock. Silly little bit but really annoying not to have.
Should fit in an envelope. If you let me know your paypal, ill pm you my address.
JC
How much for the head delivered? Not bothered about a few bent valves
