mk3 fuel filler issue...
fuelled the car up earlier and realised the fuel flap wasnt sitting correctly, like someone had pushed it in. on closer inspection, the top of the filler pipe is loose in the bodywork, the seal seems to have come away somehow?
see theres a metal clip of sorts within the seal which looks ok. is it just a case of pulling the filler neck back through and reattaching the seal/clip?
  • Views 847
That's exactly right. Its like a rubber hood that slots into the body and then there's a rigid metal ring inside that expands to keep it in place. Easy peasy fix!
You don't even need it, but it stops dirt flung from the back wheel pissing out the flap and covering the cap.
When you jetwash the car its a good idea to remove it and shove the jetwash in there, blast out all the dirt which is causing corrosion behind there.
