mk2 saloon rear glass removal
anybody taken out the saloon rear window without breaking the rubber seal. how easy is it to do?
  • Views 960
get inside and pull down the rubber seal working it over the window profile at one corner place a thin plastic wedge in the corner and work along gradually bit by it once you have worked along about three inches place another wedge and so on tll you have worked the whole top out take it down the sides about half way you should then be able to ease te glass out
