GTI Heated Seats
Hi all!
I've got myself a polo gti for a while now with the number 1 seats in
found some genuine polo gti heated seats for sale, bought them but unsure how i get the heated seats working
is the wiring already there from factory as cant see why it would not be, if it is where is it, if not what do i need to do
cheers
Edited by upbeatbon
  • Replies 8
  • Views 6.7k
  • upbeatbon
    upbeatbon
    Is that loom you stated for both seats and i was going to buy this loom http://www.ebay.co.uk/itm/VW-Golf-Bora-Pas...=item53ea9fbc2e but as you can see its near on twice the price. do the company
Is it the polo 6n2 heated seats? With the 6n2 controls?
That's it.
Well, i was in the same situation as you.
You can either make your own wiring loom up or buy one. I bought one from Kufatec ( http://www.kufatec.nl/shop/en/Volkswagen/P...ess-VW-Polo-6N2 ), in my opinion, worth the money as by the time you bought all the wire theres only £20 in it.
From that you have to route the cables, i did it along the door sills, under the plastic, then under the carpet through the hole, and over the centre console to the other side.
Youll need an earth point - i used the bolt holding the dash on, right next to the bonnet catch
Main live feed - i got this from the main feed from the battery ( youll need a spade connector ) 15 amp fuse
Switched live - Got this from the ignition, yellow black wire ( see pic ) Iv used a 1 amp fuse and its ok
Illumination - I got this from the headlight switch (dont ask me which wire) but this could be piggy backed off of the heated rear window switch
Switched live - with blue fused wire attached
do the company you stated ship to UK.
thanks
Yes, i got mine from kufatec, takes a week or so but they do ship. And yes its for both seats, just add the two switches and two seats.
The kufatec one is only 1 colour, but there is writing on them, which you will have to translate, or use a multimeter with a circuit diagram, below [=
Edited by chrisjb330
ideal will order it this week ready for my new 6n2 :)
Let me know if you get stuck.
will do, had switches arrive from ebay today so going to get these looms bought
