Afh loom problem help
Which relay do you connect the live coming from the engine loom too. Please help am really stuck. Thanks.
  • Views 363
Popular Days
is it the main live, quite a thick wire with a ring connector on the end?
if so it bolts onto one of the terminals on the white relay panel with a 10mm nut.
