Lowering 6n2
Hi,
lowing my 6n2 this weekend and just wondered how bad will the camber be?
will i need to go to a 4 wheel allignment specialist?
Also thinking of buying 15mm spacers will this rub the arch's
ps: lowering roughly 60-70mm
Thanks,
Tim
  • Views 931
I lowered mine by 40mm, i got quite bad camber was about -3.16 on one side and -4.30 on the other side. i had to buy camber adjustment bolts to sort mine out.
Yeah, and you didn't have to.
do you just loosen off the bolts?
or will i need camber adjusters?
Easier with two people to get it roughly right until you get to do it properly.
But undo the two bottom bolts on the coilvoers. Get someone to pull the brake disk holding onto the 12 o'clock position while the other tightens up the bolts. That should get you in the right kind of area.
But I'd still get it done by a professional as you need quite a few things lined up to make it drive properly. Its worth spending the money as the car will drive much better after its been aligned properly.
