Removing inner arch liners
Just wanting to know the likeliness of rust developing if you remove inner arch liners? Anyone had such issues?
Edited by Dubb87
  • Views 1k
The stones from the road will chip off the paint on the inside then this will lead to rust. depends on how long you plan on keeping the car its your shout.
Why would you want to? Stone chips may lead to rust, but it's more likely the crap and mud thrown off the road will stick to the inside of the arch, get stuck in the crevices, retaining moisture and this will lead to rot (ask any mk2 owner about the filler neck!).
The tops of your wings will rot out within two years, I know this because I forgot to put one back in, and now its gonna cost me.
If you're scraping, just trim only what's getting in the way.
I was really intending on doing this as i had the same suspicion that you all stated. I wanted to ask as i've seen so many people on here state their going to remove the arch liners an i was wondering why do it if what you all said will happen. That's confirmed my thoughts on it though.
I had no arch liners in mine for a long time and it never rusted or fell apart. Just use to make sure I cleaned properly in the arches. Cleared out all the mud and stuff.
Mikeys suggestion is the best tho. Just cut away what you don't need. Or just let the tyre wear away what you don't need depending on how lazy you are.
