Electric windows
My 6n2 is havin a colour change so thought nowadays the time to fit electric windows. I'm thinkin about buyin 2 complete doors with electric windows and simply swapping them, will the electrical connector be the same? Or has anyone done this before
No one?
The Door disconnects are the same regardless of equpiment fitted, but the wiring might not be installed inside the car :?
If you remove the connector on the door post and if the RED pins are there on the drivers side & BLUE pins on the passenger as shown in this picture below then the wiring is fitted
6N2doordisconnectElectronicwinows_zps134
It wasn't fitting in mine when I fitted them. Mine has a custom harness to support it, because the electric window loom is part of the interior harness. So either take the harness with you, if build you're on if you're competent.
Simple, really. They need a feed and a ground. Ground on the body, feed above the throttle pedal, there's spare bolts to attach shit too. Mine stay live for 15 minutes once the ignition is off, which I like. I got lucky though; haha.
Used CAT6 cable for the cables between drivers and passenger door. And it's worked perfectly for two years now! Was pretty much the first thing I did, just match colour for colour drivers on passenger side.
Thanks. mine are wired so i know what i will be doing with mine soon :thumbsup:
