wont start
I got a mk2f polo it just bogged down one night and hasnt started since iv read it could be a hall sender has anyone else had this problem and what does the hall sender do thanks guys
  • Views 538
The hall sender in the distributor 'tells' the ignition system when to send out a spark.
As there could be other problems which have caused it not to start (you normally get lots of cutting out and then not starting 'till it has stood for a while when the Hall sender is 'on its way'.
Start with the basics: Is there petrol in the tank?
Is petrol getting to the engine?
Have you got a good spark? (A 'good' spark is blue/white, if the spark is orange/red, it probably isn't good enough to fire the mixture)
Regards.
