Polo TDI Fuel Consumption
Recently i have been getting very pool fuel consumption out of my 56plate 1.4TDI polo 9n3
I put a full tank in of Diesel (Shell, BP) for the last 4-5months and I have been only getting 250miles out of the whole tank.
I had a 04 plate 1.4 TDI polo 9n before and easily got 400 miles to a tank so not sure why the difference is.
The car has been recently serviced with fuel filter changed which i thought may improve the consumption but it is the same.
Would any fuel additives help?
If so, which ones would be best to use?
  • Replies 10
  • Views 1.2k
Additives aren't going to help, you obviously have a problem. An easy thing to check is the boost piping, make sure there are no leaks.
Even 400 hundred isn't much out of a 1.4TDi. I get between 450-500 with town and A-road driving
I put a tenet in mine last week (so about 7-8 litres) done 135 miles according to the trip computer and the fuel light has only just come back on :lol:
As above check the piping, might be worth popping your MAF/MAP sense out and checking its not covered in crap and clean it
I regularly get 65mpg from my 6n2 tdi.
Have you got vcds, there's not much that goes wrong with these my money would be on a dead air mass meter or coolant temp sensor.
Also lots of smoke would be an indication of a boost leak.
Edited by lupoluke
Sorry to sound dumb, where is the boost piping? How can i tell if there are leaks?
And how do i find the MAF/MAP sensor?
Mostly likely knackered MAF or other sensors, get the car VAGCOM'd as well and get a live data report done as that'll show if the MAF is fudged as it won't show a warning light
Would air mass not affect the performace as well.
250 miles to a tank is bad, must have a fault or a leak lol.
Get it scanned with Vagcom and see what it says, probably a dodgy sensor.
Cleaned the MAF sensor with electrical contact spray yesterday, will see if it makes a difference.
After i let it dry and re-fitted the MAF the car just about started back up, when it did start alot of black smoke came out.
But seems to be fine now.
So cleaned the MAF and changed the temp sensor.
Had the car scanned and it showed no faults at all.
Still has not made a difference.
Done a whole tank of motorway driving yesterday, driving between 65-70mph and still only managed 300 miles to a tank.
What else could i do/check?
I find motorway driving at that speed is not great, I average around 50mpg at that speed but up to 70mpg going along A roads doing between 50-60mph. Guess that's ok?
Really bad evonomy sounds like the egr valve if it has one??? But don't think they have one, maybe a blockage in the air filter piping?
