6n2 abs problem don't work how to fault find ?
yer that was the symbol 16 esp is that traction control or electronic stability control? Had noidea the car had esp but there's still no abs tryed it out on the way home and still no abs light or eml light guss il have to see my mate and have it plugged in and see if there any codes!!! Also where did you get this pic from?
Electronic Stability, it uses the ABS system!!
The picture is from Elsawin.
In a previous posting I made, It's easy to fool the speedo into thinking there is no ABS fitted just put an earth wire onto pin 19 of the blue connector of the speedo or pin 16 of the pump unit and this will inhibit the fault light
there's nothing connected to the back of the clocks so il check the pump harness and il get my multi meter out and check if there's voltage at the pump harness. I'm a very experienced audio fitted and done quite a few alarms to in my time and the only wiring that's not factory i can see is the scorpion alarms but I'm going to go out now had havea really good look over it all don't suppose you have a wiring diagram for the abs system as you supplied such a good pic of the dash clocks.
  • Replies 27
  • Views 7.5k
This is the basic ABS without ESP/TCS etc
Sweet mate this lot will keep me busy 2moz these are amazing Hayes has nothing on you.
