how do I remove the door cards on 6r polo to install new speakers
Help required asap, thanks in advance
  • Views 12.2k
Not sure, post up a picture on here, but I'm certain that the handles come off, and there are screws behind it.
The panel is usually mostly held on with strong clips, these also like to break. So you may want to get some before removing.
Stupid blackberry won't let me post pics, found one torx screw at bottom of door card can't seem to ply handle of although only tried with my hands, complete novice to this, will autosave/halfords ect sell the clips I need? Thanks
The clips will be VW/TPS only
Remove the screws # 36 & 40 unclip the handle trim #15/16/17 then undo the screws #10
Release door trim from clips
– Swivel rear area of door trim panel upwards slightly.
– Pull door trim panel out of window slot.
– Now unhook Bowden cable from interior door handle on inside of door trim.
– Depending on vehicle equipment, disconnect wiring connectors from door trim
Installing
Note Before installing, check fasteners for damage and renew if necessary.
Caution
Before installing door trim, ensure that the locking mechanisms of all clips are in -position 1-.
It is not possible to install the door trim without problem if clips are in -position 2-!
– Install in reverse order of removal.
Note
When fitting door trim panel, first slide hook (front section of door trim panel) under front trim panel cover.
Then push door trim panel into window slot seal and press into clips, working from top to bottom.
Installing
Caution
Note
Where do I buy the clips from? Thanks for all the help
VW stealership or Trade Parts Specialist
The part numbers are in that screen shot from etka
Finally getting round to doing this at the weekend got my clips ect, will 13cm componants be to be to big to just slot in and replace? Thanks for all the help
