gear linkage wantwd
I'm after a complete gear linkage, but has to be a rod type.
If you are local to London, then I am willing to remove it, as it isn't the easiest thing to do.
Also, i have a complete cable linkage, so if your in need and want to swap, then let me know.
  • Views 215
will the 6n2 fit it if so got one here
I think the 6n2 uses the cable type.
But could be wrong. Does it have a mechanism that bolts to the gearbox at one end?
Thanks buddy
