problem with reversing light... changed bulb and fuse still not working... HELP please
Advice please
  • Replies 11
  • Views 20.9k
  • Not required, I've got 2 fog lamps, not had a reverse in a good few years.
Check the plug on the reverse gear switch, other than that the signal goes thrrough the body control computer on your model !!!
How do I check that lol? Complete novice
On the top of the gearbox (can't find a picture) is the reverse gear switch (two pin connector with BLACK/GREEN & BLACK/BLUE wires) remove the connector then with a paperclip short the two pins together, ignition ON and the reverse lights should be ON, if they are replace the switch if not it's a wiring check back to the body computer and if that's OK £££££
Ok, thanks, seem to have all the answers to my questions lol, is it ok to pm you if I have any more problems lol
Yep :thumbsup:
reverse lights arent mandatory nor a MOT fail so dont panic too much. I've not had one since i dont know when.
Thing is on the likes of this model, the reverse switch not only puts the lights on but also tells the computer it's in reverse to allow the likes of some of the options like, parking sensors to be activated, auto rear wipe, put the air/heater/aircon into recirc mode so your not sucking in your own exhaust fumes into the cabin as you go backwards!!
Ah, didnt see what model polo he had.
Makes a change for someone to actually fill that piece of info into their profile. :lol:
I know :lol: My first posting was going to be "what car etc" then I spotted the 6R :-)
Still no joy... Cars booked into vw next week as wipers are now not working aswell... Wouldn't mind about the reverse light not working its just the little bulb thing that glows in the dash does my head in haha! Thanks again for all the help guys
