Mk2f window outer seals
On these seals, they dont just push down like most cars, when there off you can see they hook into place, if there not hooked in properly it leaves a obvious gap between the window and the said seal, letteimg water pass though un challenged!
I've just got a brand new pair (genuine vag) and whacked them in properly and just like that I no longer have a leak! It use to run inside the door and all over my seat/carpet ( I have no door cards ),
For quite a while I use to question my rubber even tho there's nout wrong with it!
So just a lil bit of info I thought might help some people who suffer from the ball ache.
I only got new ones as I pulled them off like a animal a while ago and the metal got all bent, so Mabey just a bend back into place on not so damaged ones?
  • Views 964
I didn't think you could get these new, but I need to clip mine in better, have done for a while. How the hell do you hook them in place properly?
With the door card off and the appropriate tool ( I used a fork tool with a 45degree' ish bend) pry of the window and push it past the lip.
Obviously put a form of protection on the tool for the window!
It's a arse tho!
Edit: Mabey easier with window removed?
Edited by SuperMario
It's a arse tho!
This is the problem - you can't fit both inner and outer seals with the window removed, as the bit that bolts onto the winding mechanism doesn't fit between them. So one or other has to go in without the window in place.
I split my old ones in a few places trying to hook the damned things in place. Will have another go at them at some point.
