Interior dash lights
Hey, I have a Polo 6n and I want to change all of the dash and interior lights to blue instead of green and I want to put a blue light in the footwells in the front.. Can anybody tell me how to go about this? Thanks in advance, Tim
  • Views 733
Depends which 6n you have as there are two types of clocks, early and late, the earlyos easier as it uses two bulbs above the dials, the later uses leds soldered to a board behind the dials.
The window switches, mirror switches and rear heated window are simple enough, but they all require soldering. The heater corntol is a little more complicated.
Astor the door welllights, a simple led strip will work well.
I can supply all the switches and even the heater panel with the blue leds already fitted, if your interested then drop me a pm.
